Home » Audio » Group Build » Is there a consensus on preamp project?
Re: rectifier valves... [message #30052 is a reply to message #30050] Sun, 26 December 2004 16:55 Go to previous messageGo to next message
Sweeeeeet.
I was just thinkin' about putting together a bill of materials to build at least the amplifier circuit. Looks like we're getting closer to a finished design, so maybe I'll be able to purchase everythnig I need all at at once. I'm pretty pinched for time right now, bu I think I can assemble this preamp fairly quickly and I think it'll be fun.
Thanks for your input on this project, and to everyone else participating too!
correction... [message #30053 is a reply to message #30052] Sun, 26 December 2004 18:39 Go to previous messageGo to next message
the 261G6 is good for 2 of the required 2.4 amps of heater current for the pair of 7X6's.
regards,
Douglas
Re: rectifier valves... [message #30054 is a reply to message #30050] Sun, 26 December 2004 18:53 Go to previous messageGo to next message
What about using damper diodes? And from my perspective I am following things as they develope, but a scorecard at this point might be a good idea. To be honest if you held a gun to my head I probably could not tell the exact circuit topology we will use.
Damper diodes [message #30055 is a reply to message #30054] Sun, 26 December 2004 20:27 Go to previous messageGo to next message
Hey-Hey!!!,
Part of the restriction we are designing to is expense. The filament requirements of a full bridge worth of damper diodes is ~4A of 6.3 at a minimum. For the 6AU4 it is more like 7A. The hybrid bridge using a 6CA4 and two 1N4007-style SS diodes gives vacuum tube performance w/o big expensive filament TX's.
The 6CA4 is one tough little valve too. If we look at the size of the filter capacitance the valve can stand working into, it is right up there with a 5U4 and 5AR4/GZ34, these rectifier tubes are all good for a meduim sized stereo amp, let alone a linestage...
For a twin diode rectifier tube there are many options at the 2A/6.3 volt limit imposed by selection of the 261G6 Hammond. 6BY5 is an octal dual diode. On the smaller side, 6X5 is an octal version of the 7-pin 6X4. 6BW4 is another, lying about in the middle between 6CA4 and 6X5 capabilities.
It is a bit of a challenge to make something small, light and simple after becomming used to very overbuilt and complex-as-desired circuitry.
regards,
Douglas
Re: Damper diodes [message #30058 is a reply to message #30055] Tue, 28 December 2004 15:32 Go to previous messageGo to next message
So whatdya think on the supply? Wanna go with a pair of dual-diodes for a bridge? Or maybe go with a single dual-diode to keep it simple? 6X5's are plenty for a preamp don't you think?
there's lots of choices... [message #30072 is a reply to message #30058] Wed, 29 December 2004 18:37 Go to previous message
given a 2A/6.3V winding, there are a bunch of nice choices. the beefy EZ81/6CA4 is going to require about an amp. The octal 6BY5 is going to take about an amp and six-tenths. 6X4 and 6X5 are going to take less, and also contribute a bit more voltage drop. A 6AX5 will fit, but a 6AX6 won't. The WE412 is another neat little 9-pin, and the 6754 Bendix Hy-G-300 will also give a ~45 second warm up for the rest of the circuit due to its wonderful cermanic heater sleeve. The Bendix is also graced with a heater-cathode voltage rating exceeding its plate rating.
I would go with the 6CA4 as a first choice. 6AX5 a close second, tied with the 6BY5, also an octal.
regards,
Douglas
Previous Topic: Project idea: Plug and Play
Next Topic: now for an amp...
Current Time: Tue May 07 07:00:10 CDT 2024
