Home » Audio » Craftsmen » barbecued bits
Unrelated, but I was impressed [message #29473 is a reply to message #29469] Tue, 26 April 2005 03:50 Go to previous messageGo to next message
I had a job in a US Gov't metallurgical laboratory when I was in school. They had a bench-mounted belt sander - very old and beautiful cast iron machine. The sander was vented into a 4" galvanized smokepipe vacuum line that ran up the wall about 10 feet then overhead about 40 feet until you lost sight of it.
One day I decided to put an edge on a knife using the belt sander. What I didn't know is that the guy who generally worked in that lab used the belt sander exclusively for magnesium.
All across the ceiling the bottom of the tin pipe glowed a brilliant orange - very impressive. Zinc dripped like condensation onto the floor. Ooops.
Re: You might be in a Catch-22 [message #29474 is a reply to message #29472] Tue, 26 April 2005 10:57 Go to previous messageGo to next message
I think my local HD rent routers, but you have to supply your own bits.
If you're routing MDF in your apartment, be careful of the dust. Breathing that stuff in can't be good for you. I love the workability of MDF, but the dust it generates is a real pain. Sticks to plastic surface like iron filling to a magnet.
Re: Smokey the Bear, says "How True, Mr. Lo" [message #29482 is a reply to message #29467] Sat, 30 April 2005 23:07 Go to previous message
lon is currently offline  lon
What's HSS anyways?
Anyway I am back in this thread because I did touch up up my
one bit with some 100 sandpaper and it looks smoothe and shiney
again.
I am not ready to spend $16 on a Porter Cable bit for this job.
Gotta try it with what I have again.
And I rechucked the thing to about half of the total
3/8 in cut and will make 2 passes.
Previous Topic: What was it ?
Next Topic: You need this:
Current Time: Thu May 02 23:37:50 CDT 2024
