Home » Audio » Craftsmen » So you want to move the volume pot to the rear?
So you want to move the volume pot to the rear? [message #29125] Fri, 18 June 2004 17:58
I found this flex shaft and bushing from a place called Wire Monkey. $8.75. Eliminates the alignment problems from retro-fitting a rear pot installation.
The bushing turns the 3/8 hole in the faceplate into a 1/4" port for the shaft. The Flex Shaft is a piece of braided spring steel with 1/4" females at each end. Like a "U" joint.
Very simple and elegant solution.
Previous Topic: My new tool is a Spin Saw
Next Topic: How Thick is Thick Enough?
Current Time: Mon Apr 29 07:26:36 CDT 2024
