Home » Audio » Home Theater » HT system
HT system [message #28672] Tue, 11 September 2007 14:51 Go to next message
Crystal is currently offline  Crystal
My friend wants to build a cheaply priced HT system.
I am suggesting she use her PC as a source and processor with the suitable software such as the open source media centre. I wanted to know if there was a 5 channel digital amp along the lines of a Sonic Impact that could be used to power speakers?
Any advice would be great! Thanks
Re: HT system [message #28673 is a reply to message #28672] Wed, 12 September 2007 09:48 Go to previous messageGo to next message
There are a handful of multi-channel digital amps on the market, but most are ridiculously expensive, especially given the low-cost of their underlying technology. If you want to make an inexpensive home theater with Tripath amps, best to grab a few stereo T-amps from your favorite vendor (Sonic Impact, Trends Audio, etc.) and use them as building blocks to build-up the number of channels you need.
Re: HT system [message #28676 is a reply to message #28673] Sat, 06 October 2007 14:37 Go to previous messageGo to next message
willyable is currently offline  willyable
Are you recommending to use more than one amp? Is that going to sound bad in any way?
Re: HT system [message #28680 is a reply to message #28676] Sat, 13 October 2007 20:45 Go to previous messageGo to next message
Actually, it's better because you have more power supplies, and each are separate so isolation is good between channels. The best high-end gear uses monoblock amplifiers, which are single channel amps. Use one per channel, so stereo takes two monoblocks, five channel takes five, etc.
Re: HT system [message #28683 is a reply to message #28680] Thu, 18 October 2007 18:45 Go to previous messageGo to next message
IF you up your monoblocks do you up the quality of the stereo?
Re: HT system [message #28688 is a reply to message #28683] Sun, 21 October 2007 10:01 Go to previous message
Yes
Previous Topic: PVR hard disk recorders
Next Topic: The Power of Nightmares
Current Time: Tue May 21 22:11:24 CDT 2024
