Home » Audio » Pro Sound » Inside wiring for Crate cabinet
Inside wiring for Crate cabinet [message #27663] Sun, 19 April 2009 11:47 Go to next message
Xilefone is currently offline  Xilefone
Hi,
I have a Crate 4X12 cabinet and the inside wires have come off the speaker tabs and I'm not sure about how to re-connect them.
There are 4 wires coming into the cabinet with the following colors:
1) Red
2) Black
3) Blue
4) Yellow
Each speaker has two connection tabs, 1 red and 1 black.
Thanks for your help!
Re: Inside wiring for Crate cabinet [message #27664 is a reply to message #27663] Mon, 20 April 2009 11:50 Go to previous message
Somebody here may be able to help, but while you're waiting for a reply, I'd probably visit the local guitar shop and see if they wouldn't be willing to ask a technician to check the wiring of a cabinet they have in stock.
It's pretty easy to re-wire the whole thing, connecting series/parallel. You could trace the wires easily enough. But you could also just copy the wiring of an existing cabinet. So hopefully you can find one in a local store to copy.
Previous Topic: potentiometer
Next Topic: marshall AVT amps
Current Time: Tue May 14 19:32:21 CDT 2024
