Home » Audio » Pro Sound » fender deluxe reverb vibrato puzzle
fender deluxe reverb vibrato puzzle [message #27616] Sat, 06 September 2008 21:10 Go to next message
django is currently offline  django
lately my '65 reissue deluxe reverb has been having problems with the vibrato channel. it will only work when the intensity is turned up to 10, but as the intensity is turned up, the volume drops at the same rate, so that when the vibrato is engaged, i'm only getting about 20% of the normal volume. any ideas? thanks!
Re: fender deluxe reverb vibrato puzzle [message #27622 is a reply to message #27616] Sat, 20 September 2008 02:36 Go to previous message
Gary- is currently offline  Gary-
It could be something as simple as a pre-amp tube. You could try buying one pre-amp tube and swapping out your preamp tubes one by one, to see if you can isolate an offending tube. If this doesn't work, I'd take it in to have it looked at by a reputable tech.
Previous Topic: marshall bass state 150 problems
Next Topic: Crate Vintage 30 guitaramp
Current Time: Tue May 07 19:26:52 CDT 2024
