Home » Audio » Pro Sound » need to run my guitar through my amp and pa at same time (no line out). please help!!
need to run my guitar through my amp and pa at same time (no line out). please help!! [message #27606] Thu, 21 August 2008 21:11 Go to next message
Robert is currently offline  Robert
hi.
looking for a way to use my fender champion 110, whilst still going through the pa too. there is no line out on this amp so hoping there is a device out there that i can use to solve the problem?
thanks for your help!!
bob
Re: need to run my guitar through my amp and pa at same time (no line out). please help!! [message #27613 is a reply to message #27606] Thu, 28 August 2008 16:11 Go to previous messageGo to next message
A lot of people put microphones in front of the amps and run that through their PA. It always seemed weird to me, and it's definitely old school, but that's how they all used to do it. The only other thing you could do would be to modify the amplifier to provide a preamp line level output.
Re: need to run my guitar through my amp and pa at same time (no line out). please help!! [message #27614 is a reply to message #27613] Sat, 30 August 2008 06:40 Go to previous messageGo to next message
hi wayne
thanks for your advise!
i've been looking on the internet to see if there was anything i could buy to sort the problem, and found a A/B Y switch.
this lets you run one guitar into the input, then split the signal into two outputs. so problem solved. handy little box cos you can switch beween the two outputs,and have two inputs too.
thanks again!
robert
Re: need to run my guitar through my amp and pa at same time (no line out). please help!! [message #27620 is a reply to message #27614] Thu, 11 September 2008 18:05 Go to previous message
B.H.Booth is currently offline  B.H.Booth
Hi.
You need a di box,most have a link output and a balanced line out.Take a jack lead from the box link to your amp and a xlr lead to p.a.this should work ok.
Previous Topic: Redmere Soloist
Next Topic: marshall bass state 150 problems
Current Time: Sat Apr 27 15:05:26 CDT 2024
