Home » Audio » Pro Sound » Peavey Amp Problem
Peavey Amp Problem [message #27408] Fri, 13 April 2007 23:52 Go to next message
klrtim is currently offline  klrtim
I have a peavey valve king 2x12. Now, when I turn it up and pick heavy on my strings, I get very ugly distortion. even on the clean channel. If I play lightly, it is not too bad. I just replaced the preamp tubes and this did not fix the problem. any ideas?
Re: Peavey Amp Problem [message #27411 is a reply to message #27408] Mon, 16 April 2007 13:23 Go to previous messageGo to next message
Do you know anything about high voltage? If not, take it to a trained technician.
The inards of a tube amp are deadly if you are not careful.
That said, I had an amp that did this because of a bad power
supply filter cap. It could be any number of things, and you need
an 'oscope to view what's going on.
Chris
Re: Peavey Amp Problem [message #27416 is a reply to message #27411] Mon, 23 April 2007 11:55 Go to previous message
Ricardo is currently offline  Ricardo
Sorry I don't have insight into that particular model, but it reminds me of trouble I had with my Peavey Standard head.
It would get a horrible hum, and suck the speakers back into the cabinet until I turned it off. After a few tries at getting it fixed, it seems to be alright now, although I haven't used it for awhile.
Previous Topic: DDX3216 ANYONE?
Next Topic: Ground Lift Plugs?
Current Time: Mon May 13 12:18:59 CDT 2024
