Home » Audio » Measurement » Re: Crossover Electronics 101
Re: Crossover Electronics 101 [message #25234] Fri, 02 February 2007 07:25 Go to next message
Thnaks Wayne. So it seems the impedance of the drivers at the frequnecies in question is sufficient, and adding the series padding resistor to the impedance of the tweeter will work. This will limit the number of crossover parts one needs to buy.
-akhilesh
Re: Crossover Electronics 101 [message #25235 is a reply to message #25234] Fri, 02 February 2007 20:53 Go to previous messageGo to next message
I've found that a shunt (parallel) resistance of 1.5x to 3.0x the DC resistance of the tweeter is generally good for damping impedance peaks caused by mechanical resonance or horn 1/4λ modes.
Re: Crossover Electronics 101 [message #25236 is a reply to message #25235] Sat, 03 February 2007 06:34 Go to previous message
Thanks for the tip, Wayne.
-akhilesh
Previous Topic: converting active crossover values to passive
Next Topic: Mic Preamp
Current Time: Sat May 04 16:35:23 CDT 2024
