Home » Audio » Measurement » TS tolerances for speakers
TS tolerances for speakers [message #25157] Tue, 18 May 2004 09:17 Go to next message
Bill Grant is currently offline  Bill Grant
Hello, I'm just getting setup to measure TS parameters for speaker drivers after repair/recone. Do speakers (not repaired or damaged)vary in their parameters much? How close should you expect a "stock" speaker to live up to the TS numbers? Thanks, Bill.
Re: TS tolerances for speakers [message #25158 is a reply to message #25157] Tue, 18 May 2004 10:19 Go to previous messageGo to next message
It depends on the manufacture I've found out some of the better companies (JBL,EV, etc) it's pretty close within +- 5 to 10%, where as some of the cheaper manufactures I've seen 20-50% variance (Pioneer speakers). It's always best to measure. The woofer tester that Parts-express sells I've heard can be upto 20% off. Theres a woofer tester made by Peak Instruments that connects into a computer that's suppose to be pretty acurate.
HTH
Bill W.
Re: TS tolerances for speakers [message #25159 is a reply to message #25158] Tue, 18 May 2004 11:12 Go to previous message
Thanks for the reply. That's pretty much what I expected. Thanks!
Previous Topic: The news from Raymond
Next Topic: Audix microphones room 15
Current Time: Sat May 04 23:53:47 CDT 2024
