Home » Audio » Source » Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual?
Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13903] Tue, 06 March 2007 14:47 Go to next message
slbender is currently offline  slbender
I need to know what voltage the fuse shaped (1.25"x 0.25") bulb is that lights the VU meters. Also could use a copy of the OP Manual and Service manuals, the usual sources don't have it.
-Steven L. Bender
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13904 is a reply to message #13903] Wed, 07 March 2007 13:31 Go to previous messageGo to next message
You've probably already looked, but just in case, have you tried StereoManuals.com?
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13905 is a reply to message #13904] Wed, 07 March 2007 14:58 Go to previous messageGo to next message
You mean Rick Stout... Yeah when Mr. Bible thumpin' StereoManuals.com doesn't have it, he comes to ME!
The point is I don't have this one, so no he doesn't have it either.
-Steven
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13906 is a reply to message #13905] Tue, 20 March 2007 22:01 Go to previous messageGo to next message
You could always measure across the bulb with a voltmeter. Maybe you'll get lucky and find it's a common 12V bulb used in cars and other generic applications.
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13907 is a reply to message #13906] Tue, 27 March 2007 16:54 Go to previous messageGo to next message
Actually I did that a while back, it measured 8.45 volts without the bulb in place, so it is an 8 Volt bulb. These are not too common, but the original bulb manufacturer apparently doesn't make then any more; a second source makes 6 Volt and 12 Volt versions, or at least those are the ones stocked at Mouser, who doesn't carry the 8 Volt version if still available. I did manage to get an 8 Volt fuse bulb out of a Sony AM/FM Stereo Receiver that had gone bad, and about a week later ordered a couple of dozen 8 Volt fuse bulbs on the net as backup. I also managed to finally find the KW-8077 Service Manual in Germany, and ordered it.
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13908 is a reply to message #13907] Tue, 27 March 2007 17:25 Go to previous messageGo to next message
Very cool. Done and done.
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13909 is a reply to message #13906] Tue, 27 March 2007 22:43 Go to previous messageGo to next message
BTW, I now have one of each, a Kenwood KW-8077, and a TT-50. They look the same from the outside (except for inverted bezel and knob colors black lower bezel on the KW-8077, silver on the TT-50, and vice-versa on the knobs). But what I find very interesting is the electronics sections in both are electrically identical. The real difference is that the KW-8077 has a three motor transport, and the TT-50 a single motor transport. I'm switching the plug-in electronics sections in order to get the 8077 set working as it has an intermittant switch in its box, that loses one channel, and it seems that 3x DPDT Alps switch is no longer available.
-Steven
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13915 is a reply to message #13907] Fri, 13 April 2007 14:10 Go to previous messageGo to next message
randle is currently offline  randle
Funny thing about this conversation is that I haven't seen a kenwood in some time now. I thought all Kenwood products had stopped being made.
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13926 is a reply to message #13903] Wed, 18 April 2007 21:26 Go to previous messageGo to next message
shinningstar is currently offline  shinningstar
I don't have Kenwood KW-8077 or TT-50 RTR service manual. I think it's a good idea to take a look at this site. I've read useful information about Kenwood products.
www.tech-wiz.org/kenwood.html
Re: Anyone have Kenwood KW-8077 or TT-50 RTR Service Manual? [message #13964 is a reply to message #13903] Sat, 08 September 2007 18:03 Go to previous messageGo to previous message
kennethan is currently offline  kennethan
Hi!
Do you still need some manuals for the KW-8077? I have the schematics and parts lists if you want it.
//Kenneth Andersson
Previous Topic: Sound quality - platter speed
Next Topic: Technics Direct Drive Automatic drop broken!
Current Time: Tue May 07 09:20:10 CDT 2024
