Home » Audio » Source » Turntable buzz
Turntable buzz [message #13632] Tue, 22 January 2008 11:16 Go to next message
Chris E. is currently offline  Chris E.
Hello everyone,
I recently bought a used Technics SL-1200 MK2. Unfortunately, it makes a slight(!) buzzing noise when I connect the needle cartridge to the tone arm. The cartridge is not the problem as it works fine on my SL-1210. Also, it's not a loud or harsh buzzing noise like the one you get when you don't ground the turntable properly. Only an audible, but quite annoying one.
Does somebody know what could cause this? Thanks for your replies!
- Christopher
Re: Turntable buzz [message #13633 is a reply to message #13632] Wed, 23 January 2008 08:39 Go to previous message
Sounds like a bad connection on one of the leads. I think you're looking in the right places. I would replace the crimp connectors or at least solder the ones that are there. Might re-run or replace the wires through the tone arm.
Previous Topic: HELP! Sony ps q3 needs repair
Next Topic: Which should I keep?
Current Time: Wed Jun 12 07:17:47 CDT 2024
