Home » Audio » Source » turntables
turntables [message #13610] Fri, 14 December 2007 19:24 Go to next message
bmaia is currently offline  bmaia
i have a technique SL 1200 that emits a loud buzz. It is grounded do you think the problem is the turntable or how it is grounded. Trying to fix it because I am selling the pair/ Thanks
Re: turntables [message #13611 is a reply to message #13610] Sat, 15 December 2007 14:34 Go to previous message
I'd first check the 2 cartridge grounds, then switch carts, finally pop the bottom cover and check the ground connection to the arm cabkle circuit board for a good connection and continuity to the cartridge pins.
Previous Topic: Technics SLQD-33 Help...
Next Topic: Denon drawer belts
Current Time: Tue May 07 21:56:11 CDT 2024
