Home » Audio » Swap Meet » 39, 47, 51, 523 ohm Metal Film (Wanted 3 or 4 of each value metal film resistors)
39, 47, 51, 523 ohm Metal Film [message #97516] Sun, 17 March 2024 00:30 Go to next message
I was wondering if someone had
3 or 4 of 39 ohm metal film 1/2 watt resistors 1%
3 or 4 of 47, ditto
3 or 4 of 51, ditto
3 or 4 of 523 ohm, ditto
hanging around they do not need? I cannot find a variety pack, even on Ebay.
Cheers
pos
Re: 39, 47, 51, 523 ohm Metal Film [message #97520 is a reply to message #97516] Sun, 17 March 2024 20:44 Go to previous messageGo to next message
Hi Pos, I can assist with the 39, 47 and 51. My LCR says the first two sizes are really close the 51s measure closer to to 50.2 ohms though. They are supposed to be 1/2 watt size but look small. Then again new resistors tend to be smaller anyhow. The 523 you will have to make up with some combination. I'll see if I can pair some up for you (I'll get back later as the program is in a VM in my PC) The others are yours no charge, just let me know where to send them. PM me with the address.
Re: 39, 47, 51, 523 ohm Metal Film [message #97521 is a reply to message #97520] Sun, 17 March 2024 21:00 Go to previous messageGo to next message
Hi Pos, parallel 1K and 1.1K and it gives you 523.8 I have both in carbon film but not metal.
Let me know
Re: 39, 47, 51, 523 ohm Metal Film [message #97581 is a reply to message #97521] Tue, 02 April 2024 20:27 Go to previous messageGo to next message
PM sent Bruce.
Thanks.
pos
Re: 39, 47, 51, 523 ohm Metal Film [message #97592 is a reply to message #97581] Thu, 04 April 2024 21:52 Go to previous messageGo to next message
PM replied to
Re: 39, 47, 51, 523 ohm Metal Film [message #97630 is a reply to message #97592] Tue, 16 April 2024 19:17 Go to previous message
Thank you Bruce for sending the values I needed. It is with much
appreciation.
cheers
pos
Previous Topic: The Borealis System
Current Time: Tue May 14 09:15:45 CDT 2024
