Home » Audio » Room Acoustics » Concrete and Tin
Concrete and Tin [message #97096] Tue, 24 October 2023 19:02 Go to next message
I have access to a building with a rather large main area. It is 545 square feet (ca. 51 m²), 20 foot tin ceiling, with brick as two walls and sheet rock as the other two.
How acoustically sound is that area?
Re: Concrete and Tin [message #97098 is a reply to message #97096] Tue, 24 October 2023 21:42 Go to previous messageGo to next message
It's probably not the best. I would expect problems at low frequencies from room modes and also midrange and higher frequencies from lively reflections. Not sure about the roof either - hopefully it doesn't vibrate and buzz.
Re: Concrete and Tin [message #97116 is a reply to message #97098] Sat, 28 October 2023 17:38 Go to previous message
Wayne Parham wrote on Tue, 24 October 2023 21:42
Oh, it will. I speak from experience.
If you have floor speakers, try propping them up on cinder blocks. I think the air gap is what makes the difference, rather than leaving the speakers on the concrete floor. If that doesn't help, try throwing a rubber mat underneath the speakers, like what you'd use as a mouse pad.
Previous Topic: Textured ceilings
Next Topic: Number one mistake?
Current Time: Tue May 14 05:21:19 CDT 2024
