Concrete and Tin [message #97096] |
Tue, 24 October 2023 19:02 |
Kingfish
Messages: 548 Registered: November 2012
Illuminati (1st Degree) |
I have access to a building with a rather large main area. It is 545 square feet (ca. 51 m²), 20 foot tin ceiling, with brick as two walls and sheet rock as the other two.
How acoustically sound is that area?
Re: Concrete and Tin [message #97116 is a reply to message #97098] |
Sat, 28 October 2023 17:38 |
Madison
Messages: 327 Registered: June 2017
Grand Master |
Wayne Parham wrote on Tue, 24 October 2023 21:42
Not sure about the roof either - hopefully it doesn't vibrate and buzz.
Oh, it will. I speak from experience.
If you have floor speakers, try propping them up on cinder blocks. I think the air gap is what makes the difference, rather than leaving the speakers on the concrete floor. If that doesn't help, try throwing a rubber mat underneath the speakers, like what you'd use as a mouse pad.
