Home » Sponsored » Pi Speakers » 2PI Crossover
2PI Crossover [message #95741] Thu, 30 June 2022 06:13 Go to next message
ecc82 is currently offline  ecc82
I have a question regarding the 0.5mH coil in the 2PI crossover.
Can I also use a 0.47mH coil-which I have on hand?
Or do I have to buy a 0.56mH and unwind it till 0.5mH?
In Germany a 0.5mH coil is not a "normal" value...
Re: 2PI Crossover [message #95742 is a reply to message #95741] Thu, 30 June 2022 08:13 Go to previous messageGo to next message
Use the 0.47mH coil. It is just fine.
Re: 2PI Crossover [message #95743 is a reply to message #95742] Thu, 30 June 2022 09:11 Go to previous messageGo to next message
Thank you very much Wayne!
Can you please mail me the 2Pi Studio and Tower plans?
Re: 2PI Crossover [message #95744 is a reply to message #95743] Thu, 30 June 2022 10:58 Go to previous messageGo to next message
You've got mail!
If you have the room - especially if these speakers will be used as mains - choose the towers. They dig much deeper into the bass than the bookshelf model. The bookshelf model is excellent for surrounds, and its size makes it also attractive for very small rooms, apartments and flats. But most people prefer the towers for mains.
Re: 2PI Crossover [message #95745 is a reply to message #95744] Thu, 30 June 2022 11:25 Go to previous messageGo to next message
Thank you very much for the plans.
All the best!
Re: 2PI Crossover [message #95762 is a reply to message #95745] Sun, 03 July 2022 04:58 Go to previous messageGo to next message
Hello Wayne,
i can only get the new DX25TG59 model in Germany and it seems that it is 2db "hotter"than the old model.
How can i bring it 2db down?
Best wishes
Frank
Re: 2PI Crossover [message #95763 is a reply to message #95762] Sun, 03 July 2022 05:07 Go to previous messageGo to next message
Link to new tweeter:
https://loudspeakershop.eu/pobieranie/dx25tg-59-04.pdf
Re: 2PI Crossover [message #95764 is a reply to message #95763] Sun, 03 July 2022 07:14 Go to previous message
The replacement part is very similar, so no changes are needed.
Previous Topic: Small Room Suggestions
Next Topic: 8 pi speakers install tweeter waveguide inside cabinet?
Current Time: Wed May 08 05:48:18 CDT 2024
