Home » Audio » Home Theater » I want to convert my basement
I want to convert my basement [message #94863] Mon, 06 December 2021 03:44 Go to next message
Echo is currently offline  Echo
I would like to turn my basement into an entertainment room, so that I can use it both for gaming and also to watch movies etc., but I am not sure what kind of budget I should be looking at? Does anyone have any idea of how I can do this without breaking the bank?
Re: I want to convert my basement [message #94866 is a reply to message #94863] Mon, 06 December 2021 09:02 Go to previous messageGo to next message
If your basement has all concrete walls, you will definitely want to invest in some room treatments. I would line the walls with panel absorbers. Otherwise, you'll have worst-case room modes and lots of MF and HF reflections too. The acoustics in a basement are often really bad. But you can make it right - it's just that it isn't right unless you make it right if you're surrounded by concrete.
Re: I want to convert my basement [message #94933 is a reply to message #94863] Thu, 16 December 2021 18:14 Go to previous messageGo to next message
Csharp is currently offline  Csharp
Well, if you're on a budget and have tons of record albums, here's an idea. Build shelving units to specifically hold record albums. Make enough units to store enough albums to make a difference.
Re: I want to convert my basement [message #94940 is a reply to message #94863] Fri, 17 December 2021 07:09 Go to previous messageGo to next message
AcousticJack is currently offline  AcousticJack
The budget will depend on what kind of stuff you would want to have/build in your entertainment room. Maybe you could give us more information about it?
Re: I want to convert my basement [message #95008 is a reply to message #94863] Mon, 27 December 2021 19:35 Go to previous messageGo to next message
Mica is currently offline  Mica
What does your basement look like? What is it made of? I would say you have to fix your walls first (so the music sounds good coming off from them).
A gaming room would be easier and cheaper.
Re: I want to convert my basement [message #95577 is a reply to message #94863] Mon, 02 May 2022 00:34 Go to previous message
Souldude is currently offline  Souldude
Consider the gadgets you're planning on buying aside from the adjustments you'll be needing for the room. Will you be getting a new smart TV or a projector? Because choosing between one over the other will either increase or decrease your expenses.
Previous Topic: Good enough smart TV
Next Topic: Furniture with built-in speakers
Current Time: Sun May 05 05:13:18 CDT 2024
