Home » Audio » General » Toroidal Transformer for Amp
Toroidal Transformer for Amp [message #94272] Wed, 18 August 2021 23:59 Go to next message
A guy in the United States makes a solid state amp. A guy in France makes a solid state amp. How does the United States guy buy a transformer that is for 120 volts? Is the transformer marked as 120 volts and not 240 volts? How the guy in France knows he is buying a 240 volt transformer? Is it written on the transformer for 240 volts?
Re: Toroidal Transformer for Amp [message #94274 is a reply to message #94272] Thu, 19 August 2021 09:08 Go to previous messageGo to next message
Yes, and it's pretty easy and common to find both parts. This one isn't tricky - The voltage ratio is set by the turns ratio, i.e. number of turns on the primary coil compared to the number of turns on the secondary coil.
Re: Toroidal Transformer for Amp [message #94282 is a reply to message #94272] Thu, 19 August 2021 14:50 Go to previous messageGo to next message
If we had only 1 standard for volt, what would it be?
Disregard price which is the best toroidal transformer?
Re: Toroidal Transformer for Amp [message #94283 is a reply to message #94282] Thu, 19 August 2021 15:00 Go to previous message
There are a lot of good transformer brands. Choosing the "best" is subjective, like asking what is the best car.
As for voltage, that's not subjective but it's not qualitative either. There is no "best" level.
One caveat - Transmitting power long distances at high voltage and low current levels is better than lower voltage and higher current (for equivalent power) because the thermal losses are lower.
Previous Topic: Do dogs like music?
Next Topic: Earbuds
Current Time: Mon Apr 29 06:48:40 CDT 2024
