Home » Sponsored » Pi Speakers » Pi 4 plans request and question regarding alterations
Pi 4 plans request and question regarding alterations [message #93037] Mon, 01 February 2021 02:51 Go to next message
ronybilling is currently offline  ronybilling
Excited to begin my build. Could you send the Pi 4 plans? Also how narrow can I go? I know the internal space needs to be keep at a minimum the space called for in the plans but I would like the cabinets to be as narrow as possible.
Thanks
Re: Pi 4 plans request and question regarding alterations [message #93038 is a reply to message #93037] Mon, 01 February 2021 03:01 Go to previous messageGo to next message
Wayne I would also like to study the Pi 7 plans.
Thanks again..
Re: Pi 4 plans request and question regarding alterations [message #93039 is a reply to message #93038] Mon, 01 February 2021 08:48 Go to previous messageGo to next message
Please decide which model you prefer and let me know. I'll send plans when you've decided which model works best for you.
See the Pi Speakers FAQ for information to help you decide. It has information about differences between models and options and also has information about alterations and mods.
Re: Pi 4 plans request and question regarding alterations [message #93041 is a reply to message #93039] Mon, 01 February 2021 10:01 Go to previous messageGo to next message
Thanks Wayne. My decision is based on outside dimensions. Is that information available for pi7?
Re: Pi 4 plans request and question regarding alterations [message #93042 is a reply to message #93041] Mon, 01 February 2021 10:48 Go to previous messageGo to next message
The seven Pi model is two feet wide due to the midhorn. And while I appreciate the matter of size - if it doesn't fit, it doesn't fit - there is also the issue of feasibility and whether or not the corners and room dimensions are suitable for constant-directivity cornerhorns.
I'm glad you're researching this. I'll bet you're going to put together an excellent system!
Re: Pi 4 plans request and question regarding alterations [message #93136 is a reply to message #93037] Tue, 16 February 2021 08:48 Go to previous messageGo to next message
wmays is currently offline  wmays
Hi!
Currently sitting on 6x JBL2226H and I'd like to try the 4pi build, may I request some plans?! Thanks so much
Re: Pi 4 plans request and question regarding alterations [message #93139 is a reply to message #93136] Tue, 16 February 2021 10:34 Go to previous message
You've got mail!
Previous Topic: 4 Pi Crossover
Next Topic: 7 Pi plans request
Current Time: Tue May 14 14:31:05 CDT 2024
