Home » Audio » Speaker » Jbl 2226h pair for subwoofer
Re: Jbl 2226h pair for subwoofer [message #85943 is a reply to message #85941] Fri, 25 August 2017 11:16 Go to previous messageGo to next message
leimahmood is currently offline  leimahmood
One last question
Jbl recomended 4 cubic feet box with tune to 40hz is there any advantage on 5 cubic feet box
Re: Jbl 2226h pair for subwoofer [message #85945 is a reply to message #85943] Fri, 25 August 2017 11:44 Go to previous messageGo to next message
More bass, about 3dB more at 40Hz.
Re: Jbl 2226h pair for subwoofer [message #85946 is a reply to message #85933] Fri, 25 August 2017 11:48 Go to previous messageGo to next message
Wayne Parham wrote on Thu, 24 August 2017 16:58
Make the box 35" wide x 22" tall x 13" deep. Use two 4" diameter ports that are 5-1/2" long. Use 3/4" or 18mm Baltic Birch or MDF. Brace well using cross-braces (front-to-back and side-to-side) on each side of the woofer along the 35" dimension. The braces can be made using scrap cut from the panels.
If i select the box dimension
35 tall
22 wide
13 deep
Is it still fine
Dus to space in room
Re: Jbl 2226h pair for subwoofer [message #85947 is a reply to message #85946] Fri, 25 August 2017 12:10 Go to previous messageGo to next message
That's the same box dimensions I gave you. It doesn't matter how the box is oriented.
Re: Jbl 2226h pair for subwoofer [message #85951 is a reply to message #85933] Fri, 25 August 2017 14:55 Go to previous messageGo to next message
The dimension 35wx22tallx13deep is inner volume ??
And i also can use these dimensions too
30 wide
20 tall
20 deep
?? m i right
Re: Jbl 2226h pair for subwoofer [message #85952 is a reply to message #85951] Fri, 25 August 2017 17:52 Go to previous messageGo to next message
The (35" x 22" x 13") dimensions I gave you were inside dimensions. My dimensions create a box with 5.7ft3 internal volume. The additional size makes up for displacement from the parts inside.
Your (30" x 20" x 20") dimensions make a box with larger internal volume, 7ft3 to be precise. That 2ft3 is more than would be displaced by the parts.
You could go with (30" x 19" x 17"). That's pretty close to the volume of my original dimensions.
It doesn't have to be exact. Thermal changes at various power levels make more difference than a small volume or tuning change in the box. But still, try to keep it within +/- 10% of 5ft3. Otherwise, you should modify the ports accordingly.
Re: Jbl 2226h pair for subwoofer [message #85962 is a reply to message #85952] Sat, 26 August 2017 05:17 Go to previous messageGo to next message
Wayne Parham wrote on Fri, 25 August 2017 17:52
Well here for port 3-1/2" and 4-1/2" pvc pipes are avilable can u plz tell me the port size in these sizes
Or i will make square shape with mdf wood thanks
I think square shape with mdf wood will be best
Re: Jbl 2226h pair for subwoofer [message #85963 is a reply to message #85913] Sat, 26 August 2017 05:53 Go to previous messageGo to next message
Well boxex are under working
W8ing for ports
Tell me in square shape so its easy we will make here
Or pvc pipe 3.1/2" is also laying around
index.php?t=getfile&id=2002&private=0
Re: Jbl 2226h pair for subwoofer [message #85966 is a reply to message #85963] Sat, 26 August 2017 11:08 Go to previous message
You can make two ports, each that are 3-1/2" square and 5-1/2" long. Dimensions are internal. Length is from the front of the baffle panel to the termination inside.
Previous Topic: Two good deals on speakers
Next Topic: Will they get smaller?
Current Time: Sat Apr 27 19:10:06 CDT 2024
