I have a quick question about room acoustics. Does the height of the ceiling affect the sound that much? If so how would it be different in a low ceiling room than a normal room?
Wayne Parham Messages: 18676 Registered: January 2001
All room boundaries matter. The floor/ceiling mode is higher frequency than wall/wall because the distance is shorter, usually eight feet. The first vertical axial mode caused by an eight foot ceiling is 70Hz and the second one is 140Hz.
Thanks for the reply. I'm not sure that I completely understand your explanation, but at least it gives me a basis for where to start researching. Thanks again.
The height of the ceiling definitely has an effect and you should check for the nodes and reflections in a room. I have heard of people that use acoustic 'clouds' to get rid of refelctions.
