Home » Audio » Pro Sound » Removing background hiss (Removing background noise)
Removing background hiss [message #83979] Sun, 27 November 2016 05:37 Go to next message
vhfspeeks is currently offline  vhfspeeks
I've got some recordings of a lecture that I have to put online, but there's an annoying background hiss from the mic. I was hoping to use Audacity to remove it, but I'm brand new to cleaning up sound tracks. Any hints or tips really needed, thanks!
Re: Removing background hiss [message #84529 is a reply to message #83979] Thu, 09 February 2017 08:58 Go to previous message
Hylo
If you have a clean sound sample, with just the his, you can sample it in Audacity and remove matching sounds using Noise Removal under Tools. A full guide, 'cos I'm not typing one out here!
Previous Topic: Looks Bad, Sounds Good
Next Topic: What Does The NFL Use?
Current Time: Fri Mar 29 05:51:15 CDT 2024
