Home » Audio » General » What to use to hold equipment
What to use to hold equipment [message #82133] Wed, 02 March 2016 13:49 Go to next message
Lizah is currently offline  Lizah
What do you use to set all of your equipment on? I don't like the way that most of mine is stacked on top of each other, so I am looking for ideas on different shelving that will hold the weight well. Any suggestions?
Re: What to use to hold equipment [message #82180 is a reply to message #82133] Fri, 11 March 2016 12:18 Go to previous message
Vaiger is currently offline  Vaiger
I don't know how much they cost, but you can try these: http://www.theproudfootcompany.com/Stores/Soundblox/Type_RSR/RSR-8/
They are 8"x8"x16" and are made of the material they use to build sound buffering walls between freeways and residential neighborhoods.
You can paint them, put a tapestry of some sort over them, stack them as high as you want.......use your imagination. Smile
I don't represent them, I just thought it would be a neat idea.
Previous Topic: Audio Commercials
Next Topic: How Much Have You Learned?
Current Time: Tue May 14 13:51:19 CDT 2024
