Home » Audio » Speaker » Johnny5's four Pi build
Re: Johnny5's four Pi build [message #81449 is a reply to message #81424] Tue, 14 July 2015 16:49 Go to previous messageGo to next message
I'm moving ahead on my 4pi build.
All I need are the crossovers and waveguides and I'll be able to complete them. Razz
index.php?t=getfile&id=1743&private=0
index.php?t=getfile&id=1745&private=0
index.php?t=getfile&id=1746&private=0
  • Attachment: IMG_0312.JPG
    (Size: 31.46KB, Downloaded 3645 times)
  • Attachment: IMG_0311.JPG
    (Size: 32.27KB, Downloaded 3618 times)
  • Attachment: IMG_0310.JPG
    (Size: 34.82KB, Downloaded 3541 times)
Re: Johnny5's four Pi build [message #81450 is a reply to message #81449] Wed, 15 July 2015 08:30 Go to previous messageGo to next message
Lookin' good!
Re: Johnny5's four Pi build [message #81453 is a reply to message #81424] Thu, 16 July 2015 08:05 Go to previous messageGo to next message
Thanks Wayne.
I just have to decide what color to stain the cherry veneer. After that I'll shoot it with some satin clear and install the woofers, your crossovers and waveguides (once they arrive).
I hope you like the racing stripes😀.
Regards!
Re: Johnny5's four Pi build [message #81455 is a reply to message #81453] Thu, 16 July 2015 10:58 Go to previous messageGo to next message
My wife and I were wondering what those black stripes were.
Are they paint? Formica? A darker wood?
Re: Johnny5's four Pi build [message #81457 is a reply to message #81424] Thu, 16 July 2015 14:16 Go to previous messageGo to next message
Google "acrytech".
It's an acrylic coating that musicians commonly use for the exterior of say, a bass amp cabinet/pa speaker and the like.
I had some left over from the last set of speakers I built and just sold- "b741scanspeak".
I only used it for the stripe because I had laid out/cut the veneer in the wrong orientation, and
I only had enough veneer left to do the front panels with the grain running horizontal instead of vertical.
Therefore, I decided to keep the grain vertical, and throw in the stripe, so you're looking at a mistake Embarassed.
I happen to like it this way, and the speaker covers will hide it if I choose.
Regards!
Re: Johnny5's four Pi build [message #81460 is a reply to message #81457] Thu, 16 July 2015 14:35 Go to previous messageGo to next message
Oh, dude, that's cool!
Re: Johnny5's four Pi build [message #81494 is a reply to message #81460] Mon, 27 July 2015 17:22 Go to previous messageGo to next message
They have darkened quite nicely with no stain.
Here they are after several coats of clear (gloss) lacquer.
You can see the raw cherry veneer laying on the ground in front of them.
Quite a difference!
index.php?t=getfile&id=1777&private=0
  • Attachment: IMG_0324.JPG
    (Size: 32.56KB, Downloaded 3507 times)
Re: Johnny5's four Pi build [message #81505 is a reply to message #81424] Wed, 29 July 2015 17:26 Go to previous messageGo to next message
Hello all.
I'm wondering why I see so many 4pi builds with insulation installed on the bottom panel?
With the 4pi plans that Wayne sent me, under the "General construction tips", it states very clearly-
"Use R11 or R13 insulation, covering the interior top, side nearest the port and the rear".
It also says to hang a piece of insulation on the brace.
Therefore, there should be no insulation on-
1- the side opposite the port
2- The back side of the front baffle
3- The bottom.
Wayne sent me the plans about three weeks ago.
Have the 4pi's been revised?
Re: Johnny5's four Pi build [message #81508 is a reply to message #81505] Thu, 30 July 2015 14:54 Go to previous messageGo to next message
Nope, no change. You've got it right.
Re: Johnny5's four Pi build [message #81515 is a reply to message #81424] Sun, 02 August 2015 16:54 Go to previous messageGo to previous message
Updates:
My i-phone pics suck but-
The clear, gloss lacquer has dried for more than a week.
index.php?t=getfile&id=1785&private=0
I have gone ahead and rubbed the dried lacquer with 0000 steel wool, and applied and buffed out paste wax, all in an attempt to achieve a satin sheen.
It seems to have worked for the most part, although I might call it more of a "semi gloss".
How do you all think they would sound in this configuration? Very Happy
I sourced some genuine JBL recones, so while I had them stripped, I went ahead and did the final fitment to the boxes and installed the "Nutserts" or "threaded inserts" for the woofer screws.
"The saga continues" Smile
Regards!
  • Attachment: IMG_0329.JPG
    (Size: 43.79KB, Downloaded 3532 times)
Previous Topic: Digging out the old (?) ART array - some questions
Next Topic: Flanking subs
Current Time: Sat May 04 20:38:50 CDT 2024
