Home » Audio » Thermionic Emissions » High Power Output SET
High Power Output SET [message #11024] Sun, 27 February 2005 11:53 Go to next message
I wonder if anyone is experimenting with something like this?
Re: High Power Output SET [message #11025 is a reply to message #11024] Sun, 27 February 2005 14:58 Go to previous messageGo to next message
Coooool!
Be a man - run PP (nt) [message #11026 is a reply to message #11024] Sun, 27 February 2005 20:18 Go to previous messageGo to next message
Riiiight... [message #11027 is a reply to message #11024] Sun, 27 February 2005 20:38 Go to previous messageGo to next message
Let's see, Boeing has to tell PECO when they fire up their MW wind tunnel, I don't think you'll find many DIY running such things as that.
I have some DH Pentodes. 450W CCS anode rating. 120W g2 rating and a 10W g1. I am planning on a PP amp for ~300W output and still single-pair, Class A. No cooling fans needed. The glass is reated to 660 F.
they make an 833A look medium sized. The anode cap is 6SN7 sized. figure a PS for the PP amp to deliver 700 mA at 1k2Volts for the finals and drivers. G2 will be significantly lower, and run from its own supply.
regards,
Douglas
Re: Be a man - run PP [message #11028 is a reply to message #11026] Sun, 27 February 2005 22:01 Go to previous messageGo to next message
Re: High Power Output SET [message #11082 is a reply to message #11024] Sun, 15 May 2005 11:56 Go to previous message
Steve is currently offline  Steve
I bet not for audio. Takes a substation to run it.
The filament alone takes a couple of "welders" to heat it, 12 to 18 volts at 700 amps.
Cheers.
Steve
Previous Topic: ASL AQ1006 845 DT SET Amp
Next Topic: Tono Preamp
Current Time: Thu Mar 28 13:57:56 CDT 2024
