Home » Audio » Thermionic Emissions » lookin' for the Bridge...
lookin' for the Bridge... [message #11000] Fri, 18 February 2005 20:24 Go to next message
Well, what happens if you take two SE amps, details aren't too important yet, and bridge them?
Do the phase splitting well, and load the secondary properly. Compare to a PP amp running what is effectively the same load ( 2x SE load ).
Both topologies cancel the 2nd harmonic equally well. Both set-ups have the same power. One has to deal with DC on the core, while the PP should not.
any predictions on sound quality, better yet, anybody have a spare pair of SE amps?
regards,
Douglas
Re: lookin' for the Bridge... [message #11001 is a reply to message #11000] Sat, 19 February 2005 00:22 Go to previous messageGo to next message
I'm guessing on the SET amp, you're talking parallel output tubes, with one having phase reversed on the input and the output. Each tube requires its own output transformer that way. I haven't looked closely at parallel SET amps, but I'm guessing most run the tubes together, and use a single common transformer. Doubles power but doesn't cancel even harmonics. You're proposing a split-phase pair of SET's instead, yes?
exactly [message #11002 is a reply to message #11001] Sat, 19 February 2005 06:04 Go to previous messageGo to next message
The analog of splitting a PP amp right down the middle, including its OPTx. Feed them a balanced( instead of 'phase split', it sounds less like a 'PP damaged' term ).
The result will be 2x the power( minus the 2nd harmonic which gets cancelled ).
What about the sound? Aside from sonic quality impression, it seems like the worst way to accomplish PP.
regards,
Douglas
Maybe, but... [message #11003 is a reply to message #11002] Sat, 19 February 2005 06:23 Go to previous messageGo to next message
It's probably the best way to make a parallel SET. Except, of course, for the higher cost of having two output transformers.
Re: Maybe, but... [message #11070 is a reply to message #11003] Thu, 31 March 2005 10:01 Go to previous message
nymraud is currently offline  nymraud
atmaspheres
Previous Topic: Antique Sound Labs 805DT--anyone with personal experience?
Next Topic: Looking for a color code
Current Time: Wed May 01 20:08:21 CDT 2024
