Home » Audio » Thermionic Emissions » Transformers
Re: here is a pic of mine [message #10902 is a reply to message #10897] Sun, 19 December 2004 20:46 Go to previous messageGo to next message
Sweet looking rig. Can you describe the amps a little, please....Colin
that is the old one... [message #10903 is a reply to message #10902] Sun, 19 December 2004 20:54 Go to previous messageGo to next message
They have changed a bit since then, and then a new one got made.
the amps: cascaded diff amp/LTP stages( 6SN7>>6BX7 ) to PP KT90's riding a Dynaco A441. Configured in pentode mode with cathode feedback using the tertiary winding.
B+ is ~380, and the finals are idling at 110 mA for Class A operation. Choke input PS with GE motor-run caps.
I put a bit on the new ones at the link. I have gone DH for the time being.
regards,
Douglas
and since you'll be asking what is to the right... [message #10904 is a reply to message #10902] Sun, 19 December 2004 21:08 Go to previous messageGo to next message
here is a pic of the linestage. Shunt regulated with VR tubes, and active loads on the plates of the 2C50 ( it is now an adapter rig holding 2 12B4A's ).
I took that pic before I salvaged a volume knob from a scrapped Tek 517 scope I was using for parts.
regards,
Douglas
You know Douglas, dyslexia isn't all it's cracked up to be. nt [message #10908 is a reply to message #10903] Mon, 20 December 2004 23:46 Go to previous messageGo to next message
kyle is currently offline  kyle
uhhh... [message #10913 is a reply to message #10908] Tue, 21 December 2004 05:44 Go to previous messageGo to next message
please explain that one. I don't get it.
regards,
Douglas
I was looking at your moniker and... [message #10917 is a reply to message #10913] Tue, 21 December 2004 08:43 Go to previous messageGo to next message
got confused.
Re: Time frame? [message #10921 is a reply to message #10880] Wed, 22 December 2004 02:44 Go to previous message
Not sure what you mean. Drying time?
Kick plate is indeed the chassis plate.
I just priced copper and brass 20 ga. 6x10 plates at
onlinemetals.com, they were $16 and $12 respectively with $10 freight charge
2 things to watch with the mitre and tape:
1) No matter how I have cut the mitres, there are always some gaps; easy to fix by saving some sawdust and mixing it with a little white glue to make a paste and filling
2) I have switched from white or yellow carpenters glue to the dreaded polyurethane because butt mitres with the former just aren't strong enough to hold up when you plane and sand or, worse, try to chop or rout holes for plugs and such
Definitely chop all mortises before glue up.
Highly recommend cutting dadoes for splines to strengthen the joint
Previous Topic: who likes drawing composite curves?
Next Topic: Nickel Wonder Line Stage
Current Time: Fri Apr 19 12:35:08 CDT 2024
