Home » Sponsored » Pi Speakers » 2 Pi plans
2 Pi plans [message #72469] Tue, 01 May 2012 07:16 Go to next message
colin350 is currently offline  colin350
Hi Wayne,
Could I have the 2 pi plans please?
Colin
Re: 2 Pi plans [message #72470 is a reply to message #72469] Tue, 01 May 2012 07:51 Go to previous messageGo to next message
You've got mail!
Re: 2 Pi plans [message #72676 is a reply to message #72470] Fri, 11 May 2012 14:38 Go to previous messageGo to next message
nicola91 is currently offline  nicola91
could i have the pi 2 tower plans please??
little question:
if i put the speakers on the shortest side does the tower works anyway??
p.s. sorry for my bad english!!
nicola
Re: 2 Pi plans [message #72691 is a reply to message #72676] Sat, 12 May 2012 01:19 Go to previous messageGo to next message
You've got mail!
As for mounting the speakers on the 13" side, I haven't tested it that way. I wouldn't expect that to be a problem, but since it's a tower, it's particularly sensitive to woofer and port position.
Re: 2 Pi plans [message #72692 is a reply to message #72691] Sat, 12 May 2012 06:57 Go to previous messageGo to next message
nicola91,
I tried that and it did sound good. I prefer the normal construction though. Hard to explain, but I found the sound to be smoother in the lower frequencies. I didn't try to measure the differences.
steve
Re: 2 Pi plans [message #72699 is a reply to message #72692] Sat, 12 May 2012 11:04 Go to previous messageGo to next message
tnx for the info!! Very Happy now i'm going to decide to build it or use the same kit to build another project...
are kits for one speaker or two??
nicola
Re: 2 Pi plans [message #72769 is a reply to message #72692] Tue, 22 May 2012 04:57 Go to previous messageGo to next message
steve f wrote on Sat, 12 May 2012 06:57
nicola91,
steve
how much smoother?? if i use this http://www.servimg.com/image_preview.php?i=10&u=16423595 the sound can be more deep??
Re: 2 Pi plans [message #72770 is a reply to message #72769] Tue, 22 May 2012 09:50 Go to previous messageGo to next message
Use R11 for internal stuffing material. Those acoustic wedges are fine for lining the walls of your listening room, but they don't work as well for loudspeaker damping material.
Kits include parts for one loudspeaker.
Re: 2 Pi plans [message #72772 is a reply to message #72770] Tue, 22 May 2012 11:46 Go to previous messageGo to next message
I read somewhere that someone had used THAT insulation inside the speakers just to improve the performance of low frequencies. that's why I asked.
Re: 2 Pi plans [message #72773 is a reply to message #72772] Tue, 22 May 2012 13:43 Go to previous messageGo to previous message
Lots of garbage on the internet. That stuff does nothing at bass frequencies. It's like it's not even there below several hundred Hertz.
Honestly, no stuffing material works at bass frequencies. It would have to be several meters thick, truly larger than the box. What we're expecting from this stuff is attenuation at midrange frequencies and higher.
So forget about doing anything to modify bass frequencies with stuffing. The stuffing is for higher frequencies. Lower frequencies depend mostly on driver and cabinet tuning.
Previous Topic: 2pi towers
Next Topic: Wood used in 4PI construction
Current Time: Fri Mar 29 06:12:45 CDT 2024
