Home » Sponsored » Pi Speakers » Request for plans
Request for plans [message #71781] Thu, 15 March 2012 04:06 Go to next message
Jay53 is currently offline  Jay53
Hi Wayne,
Eminence Omega15 used in 4Pi is not available. May I request you for a copy of 3Pi Plans as Delta12F is available.
Thanks !
Jay
Re: Request for plans [message #71782 is a reply to message #71781] Thu, 15 March 2012 05:30 Go to previous messageGo to next message
Maxjr is currently offline  Maxjr
You can purchase them here for $195: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-430
Re: Request for plans [message #71783 is a reply to message #71782] Thu, 15 March 2012 05:47 Go to previous messageGo to next message
Maxjr wrote on Thu, 15 March 2012 05:30
Hi Maxjr,
I am located half the world away. The shipping costs as much the cost of the Drivers. It is much better to buy it locally. Thanks for your help.
Jay
Re: Request for plans [message #71784 is a reply to message #71781] Thu, 15 March 2012 06:03 Go to previous messageGo to next message
Hi Wayne,
I also realized that 6Pi Corner Horn uses Delta12LF and Delta10 Woofers. Will it be better to consider this for Home Theater application than 3Pi ? are the Corner Horns placed in the corner abutting the wall or offset from the wall ?
Thanks!
Jay
Re: Request for plans [message #71788 is a reply to message #71784] Thu, 15 March 2012 13:59 Go to previous messageGo to next message
If you have the right corners, then constant directivity cornerhorns are definitely the way to go. But if you don't, then matched-directivity two-way speakers may be used with flanking subs to good effect. To learn more about each of these things, see the following links:
Re: Request for plans [message #71843 is a reply to message #71788] Mon, 19 March 2012 08:13 Go to previous messageGo to next message
Wayne,
Thanks for the links. After studying these, I understand that for my room, the Corner Horns would be more suited. My I request you for a copy of the 6Pi plans ?
Jay
Re: Request for plans [message #71844 is a reply to message #71843] Mon, 19 March 2012 09:50 Go to previous messageGo to next message
You've got mail!
Re: Request for plans [message #71862 is a reply to message #71844] Wed, 21 March 2012 00:17 Go to previous messageGo to next message
Wayne,
Thanks for the plans. I am not quite clear as to where does the mid woofer gets located ?
Jay
Re: Request for plans [message #71866 is a reply to message #71862] Wed, 21 March 2012 08:05 Go to previous message
The woofer is in the bass bin. It is rear-facing in the constant directivity cornerhorns. Does that answer your question?
Previous Topic: Horn/Waveguide dimensions and beamwidth
Next Topic: Novice and maybe silly question about R3
Current Time: Tue May 07 14:49:01 CDT 2024
