Home » Audio » Source » Displaying Vinyl
Displaying Vinyl [message #71383] Thu, 16 February 2012 18:10 Go to next message
LeeLee is currently offline  LeeLee
I have quite a record collection, and I would like to put them on display. Right now, they are housed in crates. I want some kind of cabinet, with glass. Anything will do, I guess. How are your records displayed?
Re: Displaying Vinyl [message #71392 is a reply to message #71383] Thu, 16 February 2012 20:27 Go to previous messageGo to next message
Hi A long as they are vertical (not leaning) and not subject to heat or such pretty much anything is OK. You can stack them horizontally, but if you leave them that way a long time the jackets will tend to stick together and the images will come off some.
Re: Displaying Vinyl [message #72372 is a reply to message #71383] Wed, 25 April 2012 04:41 Go to previous messageGo to next message
Csharp is currently offline  Csharp
I just have mine vertically on a shelf. I've been stacking them that way since the 70's when I started buying them. Never had a problem with warping or anything else.
Re: Displaying Vinyl [message #74566 is a reply to message #71383] Sat, 24 November 2012 22:03 Go to previous messageGo to next message
I have mine on a shelf that you can access from 2 different rooms. They're vertical as well which is how I've always stored them. Some of the better one's I want to start framing and putting on walls though with maybe some accent lighting.
Re: Displaying Vinyl [message #74952 is a reply to message #71383] Sat, 15 December 2012 03:27 Go to previous messageGo to next message
srdmind is currently offline  srdmind
I had my favorite first edition records framed, I don't even play those. For the others I have a shelf, where they're grouped by alphabetical order, makes my life a whole lot easier.
Re: Displaying Vinyl [message #75120 is a reply to message #74566] Tue, 01 January 2013 15:59 Go to previous messageGo to next message
timron is currently offline  timron
Kingfish wrote on Sat, 24 November 2012 22:03
This sounds absolutely awesome! Did you happen upon a property that had shelving like that already installed, or did you knock out a wall and build the shelving yourself?
Re: Displaying Vinyl [message #75129 is a reply to message #71383] Tue, 01 January 2013 18:02 Go to previous messageGo to next message
iLoveiPod is currently offline  iLoveiPod
LeeLee wrote on Thu, 16 February 2012 18:10
I don't know how many records you have, but have you ever thought about something like a China cabinet? Rather than displaying fine China, you could display your records vertically.
Just a thought. Wink
Re: Displaying Vinyl [message #76797 is a reply to message #71383] Sun, 19 May 2013 04:27 Go to previous message
Azuri is currently offline  Azuri
That's not a bad idea ilove. Regular bookcases can do as well. The trick is to find something big enough to where you can display those albums "front out" so you can see the cover art.
Previous Topic: Tapes
Next Topic: $9500 XLR Cable?
Current Time: Sun May 12 04:24:30 CDT 2024
