Furniture & Room Sound [message #67020] |
Tue, 12 April 2011 10:24 |
audioaudio90
Messages: 623 Registered: October 2010
Illuminati (1st Degree) |
It's amazing how much furniture can change the sound of a room. We had to clear out a room to paint it and now it's reverb and flutter echoes galore.
Re: Furniture & Room Sound [message #67033 is a reply to message #67032] |
Wed, 13 April 2011 10:36 |
Messages: 18683 Registered: January 2001
Definitely. Most rooms are pretty lively empty. Large (padded) furniture does a world of good damping midrange frequencies and higher. Shelves can diffuse sound, which can be especially helpful along the opposite wall, where the speakers are facing.
One piece of furniture that isn't helpful is a large coffee table placed in front of the listeners, between them and the speakers. This can cause a very large midrange notch. Best to avoid that, use end tables instead.
Bedrooms are sometimes pretty good acoustically, in spite of the fact they are usually smaller than living rooms, dens or home theater rooms. The bed damps the lower midrange, prevents what would otherwise be a floor bounce notch. It's the opposite of a coffee table, in that the bed absorbs sound rather than reflecting it. It is also usually closer to speaker height, so the path length delta isn't as great. Of course, the speaker must be above the bed surface a little bit, maybe a foot or two.
