Home » Audio » Thermionic Emissions » Power Supply suggestions
Power Supply suggestions [message #9023] Sun, 05 June 2005 05:47 Go to next message
myles is currently offline  myles
Hi Everyone,
I have recently obtained a transformer with the following outputs; 155v, 45v, 100-0-870v, 6.3v, 13.5-0-13.5v, 6.3v, 6.3v.
I'm now wondering what I can do with it. I'd like to use it to power a SET amp (or if possible two small SET amps)but am not sure how I would configure the power supply.
Does anyone have any suggestions as to how I would do this or alternate uses for this transformer (besides boat anchor)? Any opinions or advice much appreciated.
Thanks,
Myles
how much does it weigh? [message #9026 is a reply to message #9023] Mon, 06 June 2005 19:03 Go to previous messageGo to next message
that will give a bit of estimate of its power/amperage delivery capacity.
regards,
Douglas
Re: how much does it weigh? Close to 5lbs [message #9027 is a reply to message #9026] Tue, 07 June 2005 01:34 Go to previous messageGo to next message
It weighs almost 5lbs.
Re: how much does it weigh? Close to 5lbs [message #9032 is a reply to message #9027] Sat, 11 June 2005 12:56 Go to previous message
that'ws pretty small for an amp. Let alone a stereo amp. My preference goes to PS that requires a look at the floor loading specifications...but I don't usually get to that extreme level.
regards,
Douglas
Previous Topic: SEX
Next Topic: Stand alone stereo tone controls anyone?
Current Time: Fri Mar 29 09:54:39 CDT 2024
