Home » Sponsored » Pi Speakers » Info to compare Pi models
icon5.gif  Info to compare Pi models [message #67085] Sat, 16 April 2011 23:46 Go to next message
NEO Dan is currently offline  NEO Dan
Very Happy
I received the plans but I still have questions...
Where would I find general info like system sensitivity, impedance plots, and FR polar plots to compare Pi models.
Thanks,
The Nosy Bastard Embarassed
Re: Info to compare Pi models [message #67087 is a reply to message #67085] Sun, 17 April 2011 00:49 Go to previous message
Basic specs are here:
More detailed specifications for the four π model (plans you requested) is here:
Other measurements you might find interesting are here:
You can see the measurement of the size and position of the forward lobe in the "Vertical Nulls" video in this post:
The main differences between each model can probably be summed up in a couple paragraphs:
The small two-ways (one π / two π) are high-efficiency cone/dome speakers. They're great as surrounds or secondary systems. The two π tower is capable of deeper bass.
The three π and four π are matched-directivity two-way speakers. The six π and seven π are constant directivity cornerhorns. More information on the significance of each design type is in the whitepapers listed below. the eight π is sort of a hybrid, and can be thought of as an entry level constant directivity cornerhorn, although corner placement isn't absolutely mandatory on that design.
The biggest difference between the three π and four π speakers is the the midwoofer families available. This is also true for the six π and seven π cornerhorns. The three π and six π models use the Eminence Delta 12LF woofer in the entry level model, or the B&C 12PLB100 woofer for the high-end upgraded model. There's also an intermediate option, which uses the Eminence Delta Pro 12. The four π and the seven π speakers use the Eminence Omega 15 woofer or the JBL 2226, as an upgrade option. All models can use an Eminence PSD2002 compression driver or the optional B&C DE250 driver.
Previous Topic: In-wall Baffle
Next Topic: best choice for DJ studio
Current Time: Wed Jun 05 12:40:12 CDT 2024
