Home » Audio » Home Theater » DVR - DVD
DVR - DVD [message #66899] Mon, 04 April 2011 21:37 Go to next message
iDummy is currently offline  iDummy
I used to have a DVR when I had satellite service. I now would like to record some of the stuff from the regular TV. Should I buy a DVR for this or a DVD player with recording capabilities. Is there a way to have a hard drive to record TV other than with a DVR?
Re: DVR - DVD [message #66903 is a reply to message #66899] Mon, 04 April 2011 22:17 Go to previous message
If you just want composite video in/out, then you can use one of the DVRs made for recording cameras and the like. You'll see them used in security systems. But if you want to also use them as a tuner/switcher for your satellite or cable TV, you probably will run into dead ends. These guys have tying arrangements with the DVR/tuner manufacturers and they won't let you introduce a "foreign" device on the line. You can hook it up, but they won't enable it, even if it's the exact same model as the devices they use.
Previous Topic: From laptop to TV screen
Next Topic: Denon AVR-1907 Trouble
Current Time: Fri May 03 16:44:51 CDT 2024
