Effect of Length [message #63531] |
Mon, 26 July 2010 13:24 ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Lancelot
Messages: 99 Registered: February 2010
Viscount |
Does the length of a audio cord affects the quality of the sound produced? I know that this is true with the internet connection but how about with audio connection?
Re: Effect of Length [message #63536 is a reply to message #63531] |
Mon, 26 July 2010 21:40 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Adveser
Messages: 434 Registered: July 2009 Location: USA
Illuminati (1st Degree) |
Very very little. Let me know what you are dealing with, such as AWG and the specific length and I can give you exactly what the specs should be as far as Resistance. My circuits book has this stuff in there and i'll be glad to let you know.
http://adveser.webs.com/
Re: Effect of Length [message #63591 is a reply to message #63564] |
Sat, 31 July 2010 23:17 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Adveser
Well, that is because the difference is typically very small. When I asked my teacher about this, he looked at me like I was crazy because he knows I am talking in the sense of a 16awg wire being a half inch shorter on one speaker. Naturally there are always conditions where it would become a bigger deal, but in a more general way, it isn't an issue, but some think it extremely important to correct even the slightest thing. Just use the chart and move the decimal places correctly. If it falls somewhere between the usual 10% tolerance, it is not worth the hassle. If you wanna be really accurate maybe go 2-5% tolerance. There is a calculator down at the bottom that might help.
Here is the chart:
http://www.powerstream.com/Wire_Size.htm
