Home » Audio » Silicon Valley » Proper fuse for Ueri power amp
Proper fuse for Ueri power amp [message #7854] Tue, 04 October 2005 10:14 Go to next message
josh is currently offline  josh
I recently purchased three used Ueri power amps. They all need new fuses as the fuses are missing. The back of the power amp says they need either 2 amp at 120v or 4 amp at 250 v. When I went to buy fuses the guy at the electronics store argued with me about the proper fuses to use, he said it didn't matter what the back of the amp specified in 120 v, that I should only pay attention to the 4 amp at 250 v fuse rating. Since I am running this amp at 120 v, shouldn't I use the 2 amp 120 v slow blow fuse that is specified on the back of the amplifier?
Re: Proper fuse for Ueri power amp [message #7855 is a reply to message #7854] Tue, 04 October 2005 16:53 Go to previous messageGo to next message
You are right. Get the proper fuse for 120VAC.
Re: Proper fuse for Ueri power amp [message #7856 is a reply to message #7855] Wed, 05 October 2005 07:34 Go to previous message
Thanks, although I was wrong in my original posting it was a 4 amp 120v fuse or a 2 amp 250 v fuse. I tested a 2 amp 250 v fuse with the amp and had no problems.
Previous Topic: ST L9111 ic info
Next Topic: class D
Current Time: Mon May 06 23:44:44 CDT 2024
