Members Members   Search Search   Help Help   Register Register   Login Login   Home Home    RulesPosting Rules    Sponsor the site and get a T-Shirt!Get a T-Shirt!   ART Radio ART Radio
Home » Audio » General » Speaker Spikes (For my ART arrays)
Show: Today's Messages  :: Show Polls :: Message Navigator
Switch to threaded view of this topic Create a new topic Submit Reply
Speaker Spikes [message #61640] Thu, 31 December 2009 14:43 Go to next message
Shane  is currently offline Shane
Well, with Xmas and the rest of the month going to hell in a bucket, I will hopefully be ready for carpet in my music room in the next several weeks.
I'm needing to put spikes or something on the ART arrays to level them out and give them some stability on the carpet and was thinking about using some arrow points from my hunting stash. The points are screw in obviously and come with aluminum inserts. The only problem I see is that the threaded portions are somewhat small at about 3/16" or so (I've never bothered to measure for sure) I can't see spending $50 on 1" spikes on these speakers, it just doesn't seem to keep with the spirit of things.
Re: Speaker Spikes [message #61642 is a reply to message #61640 ] Thu, 31 December 2009 17:13 Go to previous messageGo to next message
Wayne Parham  is currently offline Wayne Parham
That's a really cool idea, Shane. Sounds like it should work great. It's a no-nonsense approach too. I like it!
Re: Speaker Spikes [message #61644 is a reply to message #61642 ] Thu, 31 December 2009 21:20 Go to previous messageGo to next message
And there are many different "styles". Here are just a few of those out there:
http://www.archerywarehouse.com/FIELDTIPS.htm
Re: Speaker Spikes [message #61660 is a reply to message #61644 ] Sat, 02 January 2010 06:16 Go to previous messageGo to next message
Norris Wilson  is currently offline Norris Wilson
Shane,
These points look great for speaker spike duty.
I like the Saunders Target Point, looks familiar in the speaker spike world.
There might be enough thread to install a lock nut so the point height does not move after finding proper position.
I am in for a couple dozen of these spikes, what about you?
Thanks for bringing this up, great idea.
Norris
Re: Speaker Spikes [message #61662 is a reply to message #61660 ] Sat, 02 January 2010 09:48 Go to previous message
I think they would work. Like I said my only concern is the diameter of the threaded part. Most spikes are 1/4", where arrow points are about 3/16". And you can usually get these at a lot of Walmart stores.
Here is a link to the inserts we use in arrows. Many different types as well, depending on what arrow you use. You could just drill a slightly undersize hole and press fit them.
http://www.keystonecountrystore.com/Arrow_Inserts.html
Previous Topic:Happy New Year!
Next Topic:Puzzled - Please help
-=] Back to Top [=-
[ Generate printable PDF ] [ Syndicate this forum (XML) ] [ RSS ]
Current Time: Fri Sep 10 14:22:38 CDT 2010
