Members Members   Search Search   Help Help   Register Register   Login Login   Home Home    RulesPosting Rules    Sponsor the site and get a T-Shirt!Get a T-Shirt!   ART Radio ART Radio
Home » Audio » General » Been other places for awhile but not idle
Show: Today's Messages  :: Show Polls :: Message Navigator
Switch to threaded view of this topic Create a new topic Submit Reply
Been other places for awhile but not idle [message #61383] Mon, 16 November 2009 05:23 Go to next message
Bill Epstein  is currently offline Bill Epstein
Just finished a Hagerman Clarinet to go with my Cornet
http://i415.photobucket.com/albums/pp237/wsepstein/IMG_0986.jpg
So far it doesn't sound much different than the passive with excellent ladder attenuator except much more dynamic. That's a good thing!
I really like these Lansing cases, especially as I don't have anywhere for woodworking except my rear deck and it rains every time I have a day off.
Building the Tubelab Simple SE showed me the utility of having many cheap DVMs for a hands-free way (thanks George) to test both channels at once and not poke around the high voltage
http://i415.photobucket.com/albums/pp237/wsepstein/IMG_0983_1.jpg
3 DVMs from Jameco and 3 sets of mini-grabbers, about $80. Worth it!
What's everyone else been doin'?
Re: Been other places for awhile but not idle [message #61384 is a reply to message #61383 ] Mon, 16 November 2009 09:48 Go to previous messageGo to next message
Wayne Parham  is currently offline Wayne Parham
That's really nice lookin', Bill!
I'm having a pair of three π cabinets made with bubinga. What finish would you suggest I apply? I was thinking teak oil, but I've done a lot of stuff with teak oil over the past few years. Maybe it's time for a change. I'm thinking a few coats of lacquer might look nice too. I dunno. What do you think?
Re: Been other places for awhile but not idle [message #61396 is a reply to message #61383 ] Tue, 17 November 2009 12:50 Go to previous messageGo to next message
SteveBrown  is currently offline SteveBrown
Great looking build, Bill. How does it compare to the Akido? What brand are the volume & balance pots?
Re: Been other places for awhile but not idle [message #61400 is a reply to message #61396 ] Tue, 17 November 2009 17:32 Go to previous messageGo to next message
Both pots are Panasonic PCB style, what Jim specs. I thought a long time about using one of my discrete attenuators and eliminating the balance but decided to go stock, then maybe change.
The Aikido has some of that CAT SL-1 black background magic; the Clarinet don't. But, it doesn't hum right out of the box and as you know, my Aikido is plagued by a pesky low-level 60Hz hum in one channel.It's been sitting on a shelf but now I'm inspired to take another shot at it and maybe use my new 'scope to find the hum.
Wayne, wipe that Bubinga down with lacquer thinner then spray it with real nitro-cellulose if Ok still allows it.
Re: Been other places for awhile but not idle [message #61402 is a reply to message #61400 ] Tue, 17 November 2009 19:52 Go to previous messageGo to next message
Bill Epstein wrote on Tue, 17 November 2009 17:32
Sounds cool... Where do you suggest I get it? Any specific product you'd recommend? I did a search on the internet and found a wide variety of products from NC lacquer in aerosol cans to stuff made out of ping-pong balls.
Re: Been other places for awhile but not idle [message #61404 is a reply to message #61402 ] Tue, 17 November 2009 19:58 Go to previous messageGo to next message
Woodcraft sells Behlen in rattle cans but I thought you had a cabinet-maker out there that could spray?
http://www.woodcraft.com/Family/2005524/BEHLEN-Qualalacq-Lacquer-.aspx
Most pro shops use Mohawk products in bulk. Any competent re-finish/re-upholstery shop can do the job.
Re: Been other places for awhile but not idle [message #61406 is a reply to message #61404 ] Tue, 17 November 2009 20:27 Go to previous message
Very good, I'll check into those two brands.
I do have a (new) cabinetmaker and he's applied laquer for me before. I've also taken delivery of some cabinets and tried my hand at finishing. And as a third option, there's another shop I've used that does nothing but apply finishes and restortation work.
Since these will be my cabinets, I can do the finish work myself but then again, might be better to leave it to the pros. Smile
Previous Topic:It's the end of Western Civilisation as we know it!!!
Next Topic:Variations on Pi Speakers
-=] Back to Top [=-
[ Generate printable PDF ] [ Syndicate this forum (XML) ] [ RSS ]
Current Time: Fri Sep 10 14:17:02 CDT 2010
