3pi [message #60867] |
Mon, 14 September 2009 10:18 |
lee h
Messages: 2 Registered: May 2009
Esquire |
Hi,
What would be the realistic minimum room size for the 3pi's?
Many Thanks,
Lee
Re: 3pi [message #60873 is a reply to message #60867] |
Mon, 14 September 2009 21:56 |
Messages: 18704 Registered: January 2001
The three π's are happy in any room size although I do find that eight feet is about the lower limit of any room dimension, really for just about any loudspeaker. Probably nothing smaller than 100 sq. feet with standard eight foot ceilings. I'd much rather see the room be at least twice this big, better still three or four times.
The problem with most rooms in this size range isn't so much with the mains as it is with the subs. You should use multiple subs to smooth room modes.
The smaller the room, the higher the Schroeder frequency, meaning room modes are a problem at higher frequencies. Very small areas like closets, halls and bathrooms are an example, having modes that cause peaks and valleys well into the midrange. There's nothing you can do with that. But once you get bigger than about eight feet in the shortest dimension, the modes start moving down from the midrange into the midbass and bass range. To tell the truth, it kind of works out because in too small a room, there's really no space to setup the equipment and have a place to sit.
