Home » Sponsored » Pi Speakers » Four Pi Driver Spacing
Four Pi Driver Spacing [message #60610] Sun, 16 August 2009 10:04 Go to next message
Stollie is currently offline  Stollie
Wayne, I'm thinking about building the 4 Pi,but with the intention of being able to upgrade at a later time to a 7 pi hybrid, adding the mid horn. I would like to move the HF driver out of the 4 bass bin and have it sit on top of the cabinet. Do you know what the approximate driver spacing is so I can move the LF driver higher in the box to compensate? Thank you.
Re: Four Pi Driver Spacing [message #60611 is a reply to message #60610] Sun, 16 August 2009 10:20 Go to previous messageGo to next message
The edges of the woofer and tweeter are less than an inch apart, making center to center spacing just under a foot. You're going top have to push the woofer all the way up in the cabinet, basically touch the edge to the top panel inside of the cabinet.
Re: Four Pi Driver Spacing [message #60615 is a reply to message #60611] Mon, 17 August 2009 10:05 Go to previous messageGo to next message
Thanks for the reply. So this sounds do-able withought affecting the overall sound. I also noticed in you 3pi upgrade video clip than you have your 4 pi's on stands, so I'm guessing this is an OK approach, correct?
four π speakers + multisubs [message #60616 is a reply to message #60615] Mon, 17 August 2009 15:18 Go to previous message
When I don't run subs, I always position the woofer close to the floor to avoid floor bounce. I recommend floor standing or angled risers or no more than a few inches, if subs aren't used.
If subs are used, then I usually put the main speakers on a stand between 12" and 18". This brings the sound sources up to approximately ear level (seated) but also introduces floor bounce. However, properly positioned subs can smooth this with a multisub technique. I usually use what I call flanking subs placed just a few feet from the mains and low-passed at a relatively high frequency. Those smooth the upper modal range, up to the Schroeder frequency (including floor bounce). In some cases, I suggest other subs be used as well, placed further away and low-passed at a lower frequency. These provide additional smoothing at lower frequencies.
Previous Topic: 7-Pi 10 inch mid ?
Next Topic: 2 Pi Tower Plans
Current Time: Wed Jun 05 01:04:43 CDT 2024
