room and amp questions [message #95563] |
Sat, 30 April 2022 10:27 |
mrwill2112
Messages: 6 Registered: April 2022
Esquire |
seeing how I am a neophyte... I would ask of those who know more than me.
I have a listening room that measures 10x14 (was an office) it is used for movies once in a blue moon... But mostly for music. What would be your recommendations on speakers? with the understanding that I like Rush at not quite ear bleeding levels...
I am currently using a pioneer elite vsx94thx amp to drive the curent crap (polk) do I need to get exotic tube amps?? I am not against it but my wife is... sooo
Re: room and amp questions [message #95572 is a reply to message #95571] |
Sat, 30 April 2022 19:29 |
Messages: 18686 Registered: January 2001
Kits include parts to build one loudspeaker. They include the speaker drivers, the connector panel, hook up wires, "π" logo decal and a printed copy of the plans. For larger speakers that incorporate a compression tweeter and crossover network, kits also include the crossover, Zobel woofer damper, and all cable assemblies are completed and ready to install. Every kit containing a compression driver also includes the horn flare and the bolts to mount the driver to the horn.
As for the upgrade questions, please see the Pi Speakers FAQ, specifically the section called "Models, Upgrades and Driver Characteristics." It has a couple links about options and upgrades that will probably help you decide what you want.
