Home » Audio » Thermionic Emissions » 300B Power Supply Help
300B Power Supply Help [message #9497] Fri, 20 January 2006 09:46 Go to next message
rigma is currently offline  rigma
I am building my second pair of Angela WE-91 mono blocks and am thinking of doing external power supplies this time. Everything else will be per schematic on the www.angela.com site. I was thinking CLCLC 20uf, 10H 82ohm, 40uf, 10H 82ohm, 150uf with 5R4GYB rectifier. I also have 20, 30, 40, 50 & 100uf oil caps (motor run) actually the 150uf above is a 100 & 50uf in parallel. I have these caps available and am also willing to buy other chokes if needed. Thanks for any input you can offer on this design. The goal is to get it right the first time so if anyone can suggest improvements it would be appreciated.
PS: I have the Angela universal Power Trannies 380-0-380 @ 200ma
Re: 300B Power Supply Help [message #9498 is a reply to message #9497] Fri, 20 January 2006 10:56 Go to previous messageGo to next message
You can use free PSUD2 program. I found some my messages about modelling PS with it:
http://audioroundtable.com/Tubes/messages/1397.html
http://audioroundtable.com/Tubes/messages/1398.html
http://audioroundtable.com/GroupBuild/messages/1314.html
Re: 300B Power Supply Help [message #9499 is a reply to message #9498] Fri, 20 January 2006 11:21 Go to previous messageGo to next message
paba is currently offline  paba
You can also follow the tutorial on PSUD II published in Bas Horneman's DIY magazine here...
http://www.basaudio.net/pubs/DIY_2005_5.pdf
cheers
Paba
Re: 300B Power Supply Help/Example [message #9502 is a reply to message #9497] Sun, 22 January 2006 04:51 Go to previous messageGo to next message
Here`s a one quick example...
Re: 300B Power Supply Help [message #9503 is a reply to message #9497] Sun, 22 January 2006 19:40 Go to previous message
Just wondering why power supplies on seperate chassis? I've tried this before and sorting out ground loops, finding appropriate connectors for the Ht, and the bulk of the extra chassis all made it seem less that worthwhile. I'd also ask why the Angela 91? I have made it (along with a dozen or more other 300B designs) and it always seemed less dynamic and a bit wooly to me. Have you tried other designs? While you didn't ask, I'll tell you what I've landed on as one of the best SE designs I've ever found... use a WE 417a, loaded with a 10k, 12w mills run about 10ma of current and 150v on the plate. Cap couple that to the 300b and presto! Fantastic amp!! Even better, do this with 2A3's, and/or replace the 10k with a good CCS and direct couple it. Power supply? I use cap input, one choke, a couple hundred uf's (10uf + 10H + 200uf) and you're good to go. I'll tell you, adding additional chokes and caps has been, in my experience (and verified with scope and loads of experiments), a waste of time and money. Anyway, just my 0.02 worth. YMMV..
Previous Topic: Latest AudioExpress about amp with 6DZ7 output tube?
Next Topic: Restored Citation II
Current Time: Tue Apr 23 08:05:06 CDT 2024
