| Pi 3 subwoofer [message #73227] |
Mon, 09 July 2012 06:37  |
48h350 Messages: 9 Registered: November 2011 Location: AUSTRALIA |
Esquire |
Hi Wayne, you sent me the plans for the Pi 3 sub.
Unfortunately the shipping to Australia is just about as expensive as the driver-Eminence Lab 12-itself, so i am looking for alternatives.
You did approve, in the past,the use of a car sub from JBL: GTO 1214 TD .
So I am thinking of using this driver to build the subs ( 2 )
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/BoxesandParameters/GTO1214TD.pdf
I found this piece of software to work out dimensions,port length etc. http://www.ajdesigner.com/fl_subwoofer/subwoofer.php
Is this software good enough to design the enclosure or would you use something else?
What alignment would you recommend?
Would you build a sub just as wide as the Pi 4 and use it as a stand?
Thanks for your work.
Massimo
| Re: Pi 3 subwoofer [message #73263 is a reply to message #73228 ] |
Thu, 12 July 2012 18:30   |
Esquire |
Hi Wayne I am following the road of using Pialign to model the enclosure of the above mentioned driver jbl gto1214.
(Thiele and Small parameters attached in original post)
after a while I "think" I understand how to use it. Can I confirm with you that, to get QD for your program, you do: Qd= 1/Qm + 1/Qe ?
where Qm is Mechanical Q of the driver and Qe is the electrical Q.
I obtained a Qd of 2.133
I attach the results, can you be so kind to see if they make sense?
For the dimensions, am I right to assume that volume HAS to be reached with the suggested dimension in relation with the port diameter and length ? In other words if I wanted a square faced SW, is there any way to "lead" the program to do so ?
Thanks Wayne
massimo
Attachment: JBL GTO1.PID
(Size: 0.68KB, Downloaded 23 time(s))
| Re: Helmholtz formula [message #73270 is a reply to message #73269 ] |
Thu, 12 July 2012 23:17  |
Esquire |
Great.
I get 8.4 inches long port with a diameter of 4 inches in a 15"x15"x15" box with a Helmholtz frequency of 22.87 Hz in a box of 1.27 cu ft. of volume.
Thanks for the help Wayne.
massimo
