Home » Sponsored » Pi Speakers » Excited =)
Re: Excited =) [message #68719 is a reply to message #68712] Mon, 25 July 2011 18:30 Go to previous messageGo to next message
Aki is currently offline  Aki
Wow, that looks really nice painted. Great job!
Re: Excited =) [message #68720 is a reply to message #68719] Mon, 25 July 2011 19:49 Go to previous messageGo to next message
Thank you both for your kind words.
Re: Excited =) [message #68723 is a reply to message #68720] Mon, 25 July 2011 21:15 Go to previous messageGo to next message
blah. you make me want to chuck my first 1pi and start all over. Confused
Re: Excited =) [message #68726 is a reply to message #68723] Mon, 25 July 2011 21:22 Go to previous messageGo to next message
OMG I want to smack you. That pic you posted of your 1pi made me mad I used MDF =)
Re: Excited =) [message #80370 is a reply to message #68256] Tue, 02 September 2014 23:14 Go to previous message
corradizo is currently offline  corradizo
Hi,
Great build log!
Can you tell me how you like them now that its been a couple of years? Would you change anything?
I was considering doing all 1pi's for LCR. I can possibly fit all 2pi's. Wife is the reason for going smaller. I need to put them in the walls and i worry the 2pi won't fit between the studs. I have been modeling a 14.5 x 34 x 5 version of the 2pi that i can fit between studs and have it sit flush with the wall. I worry about messing with the original design. Anyhow, I have 2 x 15" sealed subs so I definitely have below 80hz covered. My room is a media area, not a real theater per se.
Thanks,
Pete
Previous Topic: PI4 Build for home theatre
Next Topic: Any Pi builders in Ireland ?
Current Time: Sat May 04 12:51:48 CDT 2024
