Home » Audio » Craftsmen » How Hard Is It?
How Hard Is It? [message #68681] Fri, 22 July 2011 12:01 Go to next message
How hard is it to build your own equipment? I'm sure it varies by type, but generally speaking, are you always tearing your hair out or is it fun and relaxing for you?
Re: How Hard Is It? [message #68684 is a reply to message #68681] Fri, 22 July 2011 15:10 Go to previous messageGo to next message
Depends on
1. Your personal interests
2. Your skill level
3. Your frustration tolerance level.
I personally will build speakers all day, do cross-overs when I have to, might consider wiring a tube amp, won't even consider a SS amp, particularly if surface mount components are involved.
Bob
Re: How Hard Is It? [message #68771 is a reply to message #68681] Thu, 28 July 2011 08:37 Go to previous messageGo to next message
Hmm, I can see frustration tolerance perhaps being a problem for me. Laughing Perhaps I should stick with just buying equipment.
Why are solid state amps out of the question for you?
Re: How Hard Is It? [message #68791 is a reply to message #68771] Sat, 30 July 2011 07:03 Go to previous message
Hi Bob, good to see ya here.
Nymeria, I've been known to fling a capacitor across the room in frustration, but I still keep trying to build electronics 'cause of the "I did it!" factor.
Speaker-building, well...I've been woodworking all my life and I have the basic techniques mostly under control. Still, with every new speaker project, I usually find a previously undiscovered way to screw up. But then, I get to exclaim..."I did it!"
Going from a buyer to a builder is like going from a listener to a player, very satisfying.
Previous Topic: More on Formica Cabinets
Next Topic: Portable Metal Resonator for Musical Instrument
Current Time: Sat Apr 27 06:30:05 CDT 2024
