Home » Audio » General » Skullcandy?
Skullcandy? [message #65991] Sat, 05 February 2011 14:01 Go to next message
falloutgirl
I'm thinking of buying a pair of Skullcandy headphones for myself but I don't really trust the opinions of my friends who judge a headphone by how pretty it looks. I was wondering if anyone has experienced using it and how is it overall? I can't splurge since I'm just a student living off my allowance but I think Skullcandy's are well within my price range. I'm just worried it may not be worth it. I'm really unlucky with earphones/headphones and no matter what I do, they end up broken after a few months. I was thinking maybe if I tried buying headphones of better quality they'd last longer with me. What are other alternatives that I could look into? Thanks so much for the help Smile
Re: Skullcandy? [message #65995 is a reply to message #65991] Sat, 05 February 2011 16:40 Go to previous messageGo to next message
I've read bad reviews. It's a vanity product that prone to breakage.
Re: Skullcandy? [message #65996 is a reply to message #65995] Sat, 05 February 2011 18:36 Go to previous messageGo to next message
Adveser wrote on Sat, 05 February 2011 16:40
My son got some that came with his mp3 player and they lasted about a week. He's very careful with his electronics, FWIW. IMO they sounded terrible even compared to the stock iPod headphones. You might look at some of the Sennheiser earbuds, I've heard they are not too bad as far as earbuds go.
Re: Skullcandy? [message #65998 is a reply to message #65991] Sun, 06 February 2011 05:05 Go to previous messageGo to next message
falloutgirl
Oh my, so they're just really pretty looking headphones. So what I would be paying for would be the design.
Thanks Adveser and Shane. I'll try to check out Sennheiser, Shane Smile How about headphones tho? Any recommendations?
Re: Skullcandy? [message #66005 is a reply to message #65998] Sun, 06 February 2011 10:05 Go to previous messageGo to next message
What kind of music are you wanting to listen to? What is your source (PC, iPod, etc...) ? Are you going to be listening to CD quality or low bitrate downloads from iTunes? What is your budget?
Re: Skullcandy? [message #66014 is a reply to message #66005] Sun, 06 February 2011 13:09 Go to previous messageGo to next message
falloutgirl
I alternate between my laptop and iPod. Most of my music's downloaded from iTunes and as for my budget, no more than $100
Re: Skullcandy? [message #66016 is a reply to message #65991] Sun, 06 February 2011 14:01 Go to previous messageGo to next message
100 bucks buys you the indestructible Sony MDR-7506. If you don't want the warranty, you can get the cheaper but almost identical Sony V6/V600. The only difference between them is the grounding which the professional model uses two independent cold poles rather than just one you would find on the V6. No, I don't think you can really tell the difference.
Re: Skullcandy? [message #66020 is a reply to message #66016] Sun, 06 February 2011 16:27 Go to previous messageGo to next message
You might consider the Grado SR60 or SR80, both of which can be had for $100 or less. At 32ohms they will be iPod friendly and they are built like tanks. Plus if you don't like them or want to upgrade in the future you can very easily sell them at places like the Head-Fi forum for near to what you paid for them.
I've not heard the Sony MDR-7506 that Adveser recommends, but have read that because they are billed as studio cans they have a sterility to the sound they produce. Most studio headphones are like this and will show most the flaws in your source material. From my understanding they also have a really nasty spike around the 2k region that many can not deal with.
By all means try out as many types as you can if possible. Bring your iPod to the store. Check on Head-Fi.com and see if there is anyone near you that can let you listen to theirs or if a headphone meet is going to be near you. The Sony's may be perfect to you, so please take our opinions as just that. Everyone hears/perceives things differently.
Re: Skullcandy? [message #66021 is a reply to message #65991] Sun, 06 February 2011 16:37 Go to previous messageGo to next message
I looked at a few graphs other than this one, but I don't see a hump in the 2Khz region. The sony's look relatively flat to me up to 10Khz. I wouldn't worry about the rolloff past 10Khz that is displayed.
http://www.google.com/imgres?imgurl=http://image.innealtoir.com/images/mdrv6sr60.png&imgrefurl=http://www.head-fi.org/forum/thread/463529/frequency-response-graphs-are-a-curious-thing&usg=__SNbLT5wNkrrMA3-L0iYEZbcJvCU=&h=340&w=425&sz=48&hl=en&start=15&zoom=1&tbnid=btj2TglKOoeqWM:&tbnh=140&tbnw=175&ei=vyFPTfDsA5OosAOTxvX5Cg&prev=/images%3Fq%3Dsony%2Bmdr-7506%2Bfrequency%2Bresponse%26um%3D1%26hl%3Den%26sa%3DN%26biw%3D1120%26bih%3D615%26tbs%3Disch:10%2C669&um=1&itbs=1&iact=rc&dur=574&oei=SiFPTee-F4uusAOa15GXCg&esq=2&page=2&ndsp=15&ved=1t:429,r:11,s:15&tx=99&ty=87&biw=1120&bih=615
Re: Skullcandy? [message #66023 is a reply to message #66021] Sun, 06 February 2011 16:53 Go to previous messageGo to previous message
I'm just repeating what others have experienced on the Head-Fi.com forum. What I don't believe in is published specs and graphs from equipment manufacturers. You have to listen for yourself. The specs are a good place to start, but nothing replaces actual experience.
Here is a link that may help the OP.
sony mdr7506 investment dilemma
Previous Topic: Audio books
Next Topic: New Car Radio & Speakers
Current Time: Sun May 26 07:39:15 CDT 2024
