Home » Audio » Source » Keeping Vinyl Records in Top Shape
Re: Keeping Vinyl Records in Top Shape [message #65757 is a reply to message #65752] Tue, 18 January 2011 22:54 Go to previous messageGo to next message
Jorel wrote on Tue, 18 January 2011 19:37
I will follow the guide on how to clean vinyl.
I remember a show in TV before and they've shown a vinyl in bad shape. It still plays good but I think it is just another player and not the real vinyl playing. Do you think a vinyl will still play well even when the shape is not flat any longer?
I would take any means necessary to make sure it is flat.
putting it between two heavy things and a little bit of heat from a blowdryer might do wonders. Use at your own caution. Go buy some dollar records and use the blowdry to warp them and see how it works before you do it on anything worth a ...um, hoot.
Re: Keeping Vinyl Records in Top Shape [message #65788 is a reply to message #65551] Fri, 21 January 2011 06:35 Go to previous message
Jorel is currently offline  Jorel
I will have to look at that clamp later on when I have my player already. Is the clamp an optional part of the player or is it always included?
Previous Topic: Remembering
Next Topic: High Resolution Technologies' iStreamer
Current Time: Fri May 10 00:55:21 CDT 2024
