Home » Audio » Craftsmen » Effect of Length
Re: Effect of Length [message #63609 is a reply to message #63531] Sun, 01 August 2010 22:57 Go to previous messageGo to next message
Keith Larson is currently offline  Keith Larson
Hm, maybe it would help to consider a hypothetical but not too unrealistic case?
As an example consider a speaker (or combination of speakers) whose impedance is nominally 8 ohms, with a 64 ohm peak in the bass, yet falls to 4 ohms at 20 kHz. Now suppose you are using a long (or crappy) cable with an R=1 ohms and 8uH inductance. The nominal loss would be 20*log(8/(8+1))=-1dB and the bass peak would be -0.134dB. However, at 20 kHz the cables total impedance is now 1+1j ohms (1.414 angle 45'). In this case the -2.6dB. The total variation is 2.5 dB, so a better cable might help, but from a simplistic view this is really not much more than a tone control. On the other hand, Wayne's point about damping comes to mind.
Incidentally when something sounds bad, what I usually find to be most problematic are bad connections, oxidation and corrosion. Basically this is loose screws, oxidized wire and incompatible metal contacts.
Re: Effect of Length [message #63614 is a reply to message #63609] Mon, 02 August 2010 02:34 Go to previous messageGo to next message
Lancelot is currently offline  Lancelot
Keith Larson wrote on Sun, 01 August 2010 22:57
Does this mean that a wire subjected to environmental variables like rain or wind can change the volume or sound quality that run through it? I thought the cords are protected from these elements.
Re: Effect of Length [message #63623 is a reply to message #63614] Mon, 02 August 2010 09:27 Go to previous message
Insulated wires have two advantages. One is protecting the wire itself from abrasion and corrosion. As an example, you have probably seen plenty of copper wire turn green because of chemically reactive insulation, but this takes time. The other is maintaining a constant conductor spacing. For a one loop inductor, I'm pretty sire the inductance is a function of the area within the loop. Anyhow, if you 'unzip' a section of wire the inductance will go up by quite a bit.
In most instances where the wire is not severely undersized the ratio of wire to speaker resistance is usually large enough that the effects of wire resistance are un-noticeable. Its usually when the ratio is 1:10 or less that things start to become noticeable and eventually obvious. By the way I would like to add here that I understand that using the word 'noticeable' is very subjective. The bottom line is that if you have a good ear or know what to listen for, things become more noticeable, or, simpler yet, tilt your head a few degrees for a new experience! FWIW, as far as measuring goes, changes on this scale are easy to spot.
The only thing that really effects wire in the short term is temperature. The resistance of many metals (IE copper) is directly proportional to absolute temperature, so its not surprising that unless the wire is really bad and goes from cold to on fire, its not going to change much.
Note: Heat tends to build up much faster in the voice coil of the speaker with some coils potentially getting VERY hot. Temperature swings of 200'C are common, so were talking about nearly a (270+200)/270 change in resistance.
On the other hand, the connections are by far much more influenced by the environment.
Previous Topic: Nostalgic DIYers
Next Topic: I know you hate t-nuts so
Current Time: Tue May 07 10:06:26 CDT 2024
