Home » Audio » Speaker » About to start building my ART Arrays
Re: About to start building my ART Arrays [message #61259 is a reply to message #61258] Thu, 22 October 2009 15:34 Go to previous messageGo to next message
If anybody would like to build a pair of these speakers, Scott Placke has generously offered to supply all the parts at the OEM price, which is slightly less than $300. You will need to call Scott at PE and tell him you want the RMAF Art Array "kit". There is no "kit", and the Art Arrays have nothing to do with the RMAF, but that's where I see Scott every year, and if you say "Fred's RMAF Art Array Kit" he'll know what you're talking about. Smile
Here's the parts list:
Sixteen #295-301 5.25" Dayton Classic woofers
Two #264-578 Vifa DX-25 tweeters
Two #255-206 0.15mH 18ga air core inductors
Two #255-266 2.0mH 18ga air core inductors
Two #027-350 33uF electrolytic caps
Two #027-408 Dayton 0.68uF poly caps
Two #027-418 Dayton 3.0uF poly caps
Two #027-426 Dayton 8.2uF poly caps
Two #027-434 Dayton 18uF poly caps
Two #027-440 Dayton 30uF poly caps
One #095-282 pack .205 quick disconnects
One #095-286 pack .110 quick disconnects
One #100-116 50ft 16ga speaker wire
Two #260-303 speaker terminals
One #081-435 pack of 100 #6 screws
Two #004-3 three ohm resistors
Two #004-12.5 resistors
The 33uF electrolytic goes in the woofer zoebel, the 30uF and the 3uF metallized poly caps are paralleled to form the required 33uF in the tweeter circuit. The schematic also calls for a 1.2 ohm series resistor in the tweeter circuit, but I found the tweeter was too bright and substituted a 3 ohm. The 12.5 ohm is used instead of the 15 ohm in Pete's schematic - this value isn't critical. To keep things simple for Scott I request that you order this with no substitutions.
Re: About to start building my ART Arrays [message #61262 is a reply to message #61259] Fri, 23 October 2009 08:39 Go to previous messageGo to next message
mercbravo1 is currently offline  mercbravo1
Fred,
Thank you for the information. It's certainly a bonus to get the parts even cheaper.
On a seperate note, I was also intruiged by the Fredarrays you built and wondered how they stacked up against the ART Arrays? I wouldn't mind trying to build either one (assuming you dont mind someone building your arrays), but would like to hear your thoughts on if one was superior to the other.
Thanks
Nick
Re: About to start building my ART Arrays [message #61263 is a reply to message #61262] Fri, 23 October 2009 09:07 Go to previous messageGo to next message
mercbravo1 wrote on Fri, 23 October 2009 08:39
Fred,
Thanks
Nick
The Art Arrays are much better. The FredArrays were built using Silver Flute woofers and an MCM titanium dome tweeter. The tweeter had to be crossed at a relatively high frequency, and it never blended with the woofers as well as I would have liked. Also, the Dayton woofers are quite a bit less expensive than the Silver Flutes, which now sell for about $19ea versus $10 for the Daytons.
One enclosure glued up! [message #61327 is a reply to message #61263] Wed, 04 November 2009 06:54 Go to previous messageGo to next message
dbishopbliss is currently offline  dbishopbliss
I got one of the enclosures glued up last night. 22 clamps!!!
Now I need to install the insulation and the drivers. Can't wait to hear these guys.
Re: One enclosure glued up! [message #61360 is a reply to message #61327] Tue, 10 November 2009 06:37 Go to previous messageGo to next message
Here's a photo of the glue up.
index.php?t=getfile&id=98&private=0
Re: One enclosure glued up! [message #61368 is a reply to message #61360] Fri, 13 November 2009 07:06 Go to previous messageGo to next message
Here is a cell phone photo of one cabinet completed
index.php?t=getfile&id=99&private=0
Re: One enclosure glued up! [message #61369 is a reply to message #61368] Fri, 13 November 2009 09:22 Go to previous messageGo to next message
Very nice looking!
Link to more pictures [message #61426 is a reply to message #61369] Fri, 20 November 2009 13:20 Go to previous messageGo to next message
Here's a link to some more pictures and one of the attendee's impressions of the art arrays.
http://829b.com/b_2009_11.aspx
Re: Link to more pictures [message #61434 is a reply to message #61426] Fri, 20 November 2009 21:49 Go to previous message
Super cool! Looks like a good time was had by all. I really love those little local get-togethers. You get a fair amount of time to check out the gear, and some good fun with good friends. Can't beat that!
Previous Topic: Choosing Tweeters
Next Topic: Acoustic research
Current Time: Tue May 14 05:26:40 CDT 2024
